Two things:
1. As you know, the outer tire must roll further than the inner tire in a turn. Similarly, the outer EDGE of the tire must roll further than the inner edge. That edge-to-edge variation is insignificant for cars with hard, narrow tires, but can be noticeable in a car with wide sticky tires.
2. Because the outer tire must travel further than the inner tire, the front tires are not parallel except when they're pointed straight ahead; when the car is turning, the inner wheel is usually aimed along a smaller-radius circle than the outer wheel. This "Ackerman" steering, if arranged perfectly, ensures that each tire rolls smoothly without slipping, but sometimes the "perfect" arrangement is modified -- even reversed -- for high-performance cars in order to achieve certain dynamic handling characteristics. If the 12C is built with a significantly modified Ackerman geometry (I don't know whether it is), the tires will scrub sideways in tight turns.
